M52 B28 Rev Limit?
Bela
Is there a set rev limit on the standard M52 B28 engines?
6500rpm
Bela
My engine limits off around 4500 RPM, I put on a 3.25 LSD over the weekend. (it was limiting off prior to this.
I'm running a 328 gearbox with this setup, do you think theres an issue?
your ECU is running in "limp mode" so there must be a fault or an issue with a sensor which causes the ECU to default to a limp mode setting.
Do you have a way of reading or clearing codes from your ECU?
Bela
I can take it down to the garage over the weekend to have a look.
Last I checked the exhuast was blowing a little next to where the Lambda sensors are connected.
Where is the ECU located by the way? so the garage friend knows where to look.
