Hi folks, the resto of my E30 Cab is coming along ,but i have encountered a small problem with this magnetic key immobiliser.
I have the alarm key (the round headed key with the columns that you can rotate) and the matching tag with its code. My problem is that someone has moved some of the columns around and I have no idea how to reset it to the correct code on the key.
the car cranks but will not start,suspect its disabled the fuel pump.
any advise anyone could offer would be of great assistance.
Regards
Gary
Magnetic Alarm Key
aimlessrock
d1mkaz
may be this help:
or this
or this
Disconnects the ignition feed to the coil and ECU. Connect a wire between battery+ and coil + if you need to start the car in the mean time.
aimlessrock
Thanks for all your help chaps...most useful. I will be trying to sort this out this weekend.
cheers
cheers
