E36 wiring fault!
Baurluvva
Post Wed Aug 17, 2011 10:00 pm
I have an e36 325tds touring that has a strange issue....... Every time I brale or flash headlighs/ indicate the stereo switchez off and on!!!
Does anyone know where exactly the earths are for the body loom?
Post Wed Aug 17, 2011 10:27 pm
Where the dash mounts at the sides.
Post Wed Aug 17, 2011 10:30 pm
From memory, at each end of the dash, level with the bottom of it.
Baurluvva
Post Wed Aug 17, 2011 10:59 pm
Thanks, i'll try and clean em up!
Post Thu Aug 18, 2011 9:00 am
Shouldnt need cleaning up and rarely gives a problem unless somebody has been bodging stereo's or alarms in. I would be checking you have the proper stereo loom in and no butchery around it. Good luck with it though
Baurluvva
Post Thu Aug 18, 2011 9:18 am
Im usimg the factory loom and there doesnt seem to be any bodging!! I will try cleaning the earths first, then if that fails will create a new earth.
Baurluvva
Post Sun Aug 21, 2011 9:32 pm
Pulled the headunit today and run a lead tester to the power wires off the back...... The one which cuts out when the brake pedal is pushed (or indicators or headlights!! :roll: )is thev blue lead. Is this the power aerial lead? I cut the lead from the source (so no power from car) - circut tester from rear of unit on blue input..... And when brake pedal pushed there seems to be power wtf? Is the headunit shagged?
