air con temp switch,88 320
lamby
been sorting out wiring on above car and found that the air con should have a temp switch going into the main rad/looks like rad has been changed and there is no place for it.question is with this not connected will cause any issue with car running,i.e will it tell ecu its running cold and overfuel?a/c not working anyway but all there except this temp switch and proper rad.
Radiator temp. switch only controls the electric fan, and has no influence on engine running.
In my experience, replacement rads. always come with a boss for the temp switch, fitted with a blanking plug, even if it's the smaller non aircon rad.
lamby
thanks yet again,rad is moulded where it should go,will it be ok to just rig it up to a switch and turn on when air con is fixed or is the temp switch a must?only because previous owner has put a new(wrong)rad on so might aswell get use out of it
You sure it's had a new rad? As I said above, all the aftermarket new rads I've come across have had a boss and plug. All the original rads that non aircon cars left the factory with just had the raised ring in the area like yours has.
I've no idea what a genuine rad. from BMW comes with, as I've never had a customer that rich.
Switching on the aircon switches the electric fan onto its low speed in any case, so you can use a manual switch or aftermarket fan switch, if you want to, but M20 engines don't take kindly to being overheated.
lamby
might be n.o.s as its got bm pt number on it and no damage to fins etc so it seems new.i,ll bung a manual switch on it as i,ve got plenty of wire left from alarm removal!as for overheating my first job was a new viscous swiftly followed by a cambelt.
