m40 hard to start at night in the cold?
bmw9818
Post Tue Aug 16, 2011 3:19 pm
its really weird, at night when its colder, the car struggles to start about 6-7+ cranks low idle then cuts out, when i put my foot on the gas nothing happens, this has been intermittent, sometimes happens worse and refuses to start at all when the steering is turned as well? but allways when cold..
just curious is it cause of the pas pump.. engine struggling to turn this over :? i bought a replacement pas pump off the zone and tbh it doesnt seem to of done much in terms of power steering, its still pretty hard when parking,
when warmish it fires immediately after a day or so starting at night its a bloody mission to get it going! it starts low idle about 300, put my foot down nothing happens not revs nothing, then after pumping the pedal about a million times if the car is still alive occasionally it revs up slowly to around 1-2k very very erratically up and down intermittently then dies... injectors? air leak.... it sounds liek its trying but its just choking,
i know petrol is defo leaking from the pipes i need to sort this out next week, i want to elimanate this issue as well while im at it...
its just constant problems..... :cry:
bmwbmwbmw
Post Tue Aug 16, 2011 6:11 pm
first sort your petrol pipe issue out, then change your temp sensors and see if that has made any difference, then check for any split air/breather pipes
89' e30 cabby (road project)
89' mazda 323 turbo 4x4 bf (road project)
89' mazda 323 turbo 4x4 bf (died, it still has its place in my hart) im really sorry for abusing you, please forgive me
99' 525i sport manual with m5 bits (daily driver)
Post Tue Aug 16, 2011 6:58 pm
If you have a leaking fuel line, then you will be losing static fuel pressure, which will make it slow to start.
Alternatively, if leaking injectors are the problem, improving static fuel pressure will make things worse!
Get the leak fixed, then ideally get a fuel pressure gauge on it, to see what happens to the pressure when the engine is off.
Problems with the engine water (blue) temperature sensor could also be the problem, or a combination of all these things.
Your last sentence is the giveaway. You're describing a typical long term neglected E30 in need of a damn good sort out and service.
