lolipop removal
bigdoe
Post Sun Aug 14, 2011 3:47 pm
i'm changing the wishbone on my car, i've got the old one off no problem but i can't get the lolipop separated from the wishbone, what's the best technique?.
DHFiS
Post Sun Aug 14, 2011 4:36 pm
A hole saw through the rubber then an angle grinder to gently cut away the piece that remains on the arm.
Undo the blade on a hacksaw and pass it through the lollipop so you can cut a through the metal ring.
bigdoe
Post Sun Aug 14, 2011 4:41 pm
DHFiS wrote:A hole saw through the rubber then an angle grinder to gently cut away the piece that remains on the arm.
i wanted to re-use the lolipop bush.
buzz6353
Post Sun Aug 14, 2011 4:56 pm
you will need a set of pullers and will need to clean up the part your pulling the bush over with some emery cloth then use some lubricant ..washing up liquid works
kman82
Post Sun Aug 14, 2011 5:08 pm
You can re-use the lollipop! Should be easy enough if you've got the wish bone off the car. You'll need to replace the bush anyway so you need a big hole saw to drill out the 3 spokes of the old bush (assuming it's not a solid m3 type) . If youre binning the wishbone you can leave all the crap on there. To get the metal ring out of the lollipop, you can carefully use a hack saw and a chisel.
bigwinn
Post Sun Aug 14, 2011 5:24 pm
buy a new one with the bush already installed- £30 if memory serves right from GSF?
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Post Sun Aug 14, 2011 7:28 pm
If you really want to reuse the bush itself, push a very small screwdriver blade between the bush and pin, and get some silicon grease in there. Repeat at several points around the pin, and from both sides as far as possible, and it should be possible to slide it off.
Before fitting it to the new pin, it's essential that you totally remove every trace of silicon grease, and use a mixture of 50% water and 50% washing up liquid to slide it in place, with the bush sitting in the same rotational position as it will when the car is on the ground and at normal ride height.
It's essential that the bush does not rotate on the pin when in service. Suspension movement must be by the twisting of the bush.
