sunroof seal
jimmymig
anybody got any tips on fitting sunroof seal do you need to remove the panel
Yes - trying to remove & refit the seal with the panel in-situ will just be more fiddly than its worth.
They are a tight fit even with the panel removed.
Very difficult to do without removing the panel.
Two points: The one piece seal is considerably cheaper than the two piece one.
If you're trying to cure water leaking into the cabin you'll be disappointed - the primary purpose of the seal is to prevent wind noise. Water that gets past the seal is collected by the channel around the sunroof and a moveable gutter behind it.
e301988325i
Can anyone assist with where to get one, mine's worn through and the inner rubber is poking out of the top!!
I said:
e30topless said:
lock the wife in there
alexdejonghe
May not be the cheapest, but Cotswolds (BMW dealer that advertises on here) sell them for £60...It's on my to-buy list as well!
