sunroof seal
jimmymig
anybody got any tips on fitting sunroof seal do you need to remove the panel
- **BANNED**
Yes!
Slide the panel back a couple of inches,then un-clip the liner at the front edge,allow the liner to slide back into the roof space.
Close the roof,then tilt it fully.
You will now be able to see three torx headed screws on each side,remove these and lift the lid off.
Going back,you will need to correctly align the lid,using those six mounting bolts.
When you slide the liner forward to re-fit,lift it slightly at the back,to engage the tilt guides properly.
Youth is wasted on the young.
