Almost cutting out
brettE30cab
Post Fri Aug 12, 2011 10:32 am
My 325i cab auto seems to almost stall before I pull away at lights etc, the revs drop off and jolts away from standstill. It's not been out for a proper drive in a while could it just need a blast?
gnrsoul
Post Sat Aug 13, 2011 9:09 am
check for a vacuum leak if the taking it out for a blast does not work
or could be a chocked idle control valve if it only does it when idleing?
Post Sat Aug 13, 2011 9:21 pm
Check that the throttle position switch is correctly adjusted - it must switch immediately the throttle is moved off of its stop.
Once this is correct, any remaining hesitation is generally down to a weak mixture for whatever reason - air leaks, injectors in need of a rebuild, etc.
