http://www.realoem.com/bmw/showparts.do ... g=25&fg=05
You need :
Number 13 ( but not 18, 19 as they come with No 13 and 17 can be re-used )
2 x 14
15
16
2 x 11
12
2
8
6
I also replaced the lower lever :
11 from this diagram
As you can see about half the bush in the lever is worn away - this is a big problem and its pointless refurbing the rest if the lever is fooked ! If you can't get a Z3 lever I spoke to danthe when I did mine and he said a n E36 328i lever MAY be a good compromise. I was happy with standard E30 though - when its properly rebuilt it feels great !
The realoem diarams here are correct for my touring - you need to check they match your car or adjust to suit.
Definately budget for a new gear lever even if its a standard one.
