master cylinder - age old question
Ilkorin
Post Wed Aug 10, 2011 10:45 am
Just tried to bleed the brakes on my project car and fluid is coming out of the front seal between the master cylinder and the reservoir. The M/C looks pretty old anyways so I'm thinking of replacing it. It is also for a non-ABS car, and I've just retrofitted the standard ABS. (before anyone says anything, there is a blank in the spare hole and fluid is not leaking out of that)
I have willwood 4 pots on the front and standard rear discs and have just finished putting in new solid lines and braided flexis. so I'm wondering if it's worth an 'upgrade' to the M/C while I'm at it
My options:
replace seal on old M/C
new standard M/C
E30 M3 M/C - probably pricey. How different is this to the standard E30 and the 7 series?
7 series M/C - seems to be a lot of different opinions on this mod, it looks like most agree it's not worth doing on standard brakes, but maybe on 4 pot fronts?
**BANNED**
Post Wed Aug 10, 2011 7:05 pm
Be worth a PM to BadDave to be sure about a master cylinder swap,but first,is the rubber bung thingy between the master and the reservoir fitted correctly?
Youth is wasted on the young.
BadDave
Post Wed Aug 10, 2011 7:49 pm
7 series M/C (25.4 mm E32 one) is overkill TBH.
My old E38 Brembo's worked fine with the stock 19mm M/C
E30 M3 M/C ,as you've already figured out,is a bit pricey and only really needed once you greatly increase caliper piston size.
Stock M/c will work fine and it'll give a slightly longer pedal travel but more "feel" with the 4 pots if the piston area is larger than that of the stock calipers.
If you've opted for the smaller pistoned caliper version from the Willwood catologue,pedal travel and increased feel will be reduced to somewhere near that of a stock setup,albeit with a sligth increase in braking performance.
Ilkorin
Post Wed Aug 10, 2011 8:20 pm
Not sure which willwoods I have, but they fit under the 15"bbs, and I think this setup was designed to fit the E30 so I'm now looking at just fixing/fitting a standard M/C. Why are there so many people who say the E32 one is a good upgrade then if it's overkill even on uprated brakes?
Just pulled out the rubber bungs and the front one (the leaking one) is torn at the join. I guess it shouldn't be too hard to just replace? There is also some rust around where those seals sit in the M/C so how likely is it that it's on its way out?
**BANNED**
Post Wed Aug 10, 2011 8:31 pm
Will the master cylinder clean up with some abraisive paper?
If Dave says the stock m/c is up to the job,that would be good enough for me.
Ilkorin
Post Wed Aug 10, 2011 9:50 pm
Reckon it would clean up ok, if it does I guess it's all good to reuse?
Time to buy some new seals.
