Speedo question.
kitch
Post Sat Aug 06, 2011 9:15 pm
The speedo in my car has just started playing up, when I put my foot down it stays at 0 until I let of and then reads the right speed, and everytime I accelerate it flickers up and down by 20ish mph. Any ideas what it might be? when I bought the car the speedo didn't work and I replaced a few feet of cable from the diff back and have also replaced the dials and it has been working fine for the past year or two.
**BANNED**
Post Sat Aug 06, 2011 9:26 pm
Usual answer here is just what you have done,replace the wiring to the plug on the diff!
May well be worth checking again,though,then look at the sender unit on the diff.
Youth is wasted on the young.
Barx325i
Post Sat Aug 06, 2011 9:28 pm
and the bushes that are letting the diff move around, such that you get the symptoms you suggest
kitch
Post Sat Aug 06, 2011 9:48 pm
I had a new diff mounting bush put in the other day. could it maybe the connection to the diif being a little weak?
Barx325i
Post Sat Aug 06, 2011 9:53 pm
probably & more due to fact that the wires / connector will have been disturbed in this process, and the beam bushes being responsible for the movement, but just a re-adjustment of plug will remedy the issue in the short / long term :)
kitch
Post Sat Aug 06, 2011 9:57 pm
The rear axle/beem bushes were done at the same time too, so Id hope theres no play?? I'll get it jaced up and check the connection. Hopefuly an easy fix :). Cheers for the help.
Barx325i
Post Sat Aug 06, 2011 9:59 pm
should
just be a lackadaisical connector fail
most definitely sure if you've had all the relatives replaced it'll be down to the final 1%
before jacking it up, reach underneath and give it a nudge and maybe give the wires the once over for sheer knackeredness
