gurrrrrrrrrr iv just taken out my new m52 (which i have just managed to get running) because the clutch wont disengage. I keep popping slaves, 2 e30s ones and 1 e36 one. The e36 one popped and threw its guts into the gearbox so out she came...
M20 satchs clutch new, on m20 lightened flywheel.
On inspection the fork lines up properly with the slave hole and the slave (when installed) meets the dimple in the fork and requires about 1cm of a push as the rod compresses. All is good there then. I tried to manually push the fork to disengage the clutch (using a long screw driver) but it wouldn't move at all.
Why wont the clutch move?
Clutch install, HELP!!
- **BANNED**
Plate sticking on the splines?
Wrong spigot bearing?
What gearbox are you using?
Youth is wasted on the young.
327ire
thanks for the help
im using a zf 1053401097 gearbox (328i i believe). I got a spigot bearing for a 328i from BMW so that should be ok.
- **BANNED**
Not too sure that the ZF 'box is compatable with M20 fly/clutch combo...
I'm using Getrang 240 'box(ex M40 engine)with an M20 fly/clutch with no problems.
May be better to try BMW's own combo of engine/fly/clutch/'box?
327ire
mmm, you might be right about the zf compatibility thing.
Iv just measured the distance between the bearing in the gearbox when it is 100% extended...
using this wire and measurement to compare the distance from the spigot bearing to the forks on the clutch,...
Am i right in saying that I could never actually apply pressure to the clutch in order to disengage it?
That would explain why the slaves pop out because the are being forced beyond there limit of travel.
327ire
actually, scrap that idea/test. Iv just remembered that the male part of the e36 box goes inside and through the spigot bearing, i was measuring from the front face of the spigot bearing.
- **BANNED**
I am not totaly clued up on this,but,M50 fitted with M20 fly,with M20 type clutch and an M40 'box works for me...
Looks like your combo is not working for you..clutch pedal pushing the slave's rod far enough?
e30-EVN
general rule is to use the clutch slave that was intended for the box, ie... m50 box- e36 slave..,. e30 box- e30 slave
im using m52 engine- m42 box- m20 fly+clutch- m20 release bearing- m20 slave and ive had no worries for over 6000 miles
A 2 door e30 with 8 cylinders, what could be better
327ire
Solved, i think!
No. 6 above ball pin (21511223328) is on the opposite end of the release fork from the slave rod. Mine is broken and looks like its about 10mm high instead of 20mm. This 10mm should bring the fork closer to the engine and it means that the slave rod will have less distance to travel to disengage the clutch. I might use some spacers/washers somewhere to add some distance just in case.
All this hassle over a bit thats costs $1.17. Im fed up of "learning the hard way", is there no such thing as learning the easy way? Anyway, im buying an e46 today for €2000 so that should get me to work and put a smile on my face
Thanks for the help lads, case closed!
