I've got a high pitched squeal coming from my front offside wheel bearing which relates to wheel speed. I replaced it with an SNR from ECP and almost immediately started squealing again. I thought this time it must be the brakes sticking or some debris under the pad but i took the disc and calliper off but the noise is still there, so confirmed wheel bearing!
surely it can't be the new one fookt already? what else could be causing this noise? it used to only happen when turning right at low speed, now it happens when turning right, going relativley straight and under braking, regardless of wheel speed but relative to wheel speed if that makes sense? i.e the squeal gets faster as the car does. Anyone else had this?
front wheel bearing
