HELP! please, clutch issues :(
Adams-Sideways
Post Thu Aug 04, 2011 10:25 pm
Hi guys been having a problem over the last month, my car is a 86 chromie 325i. The clutch has always been very high and probly on the way out but recently 1 out of every 10 times i start the car il put the car in gear and it will get stuck, clutch pedal wont come up and idle goes all over the shop then dies. Then next time i start it will be fine? Only happens now and then and never once the car is has moved a few hundred feet?
Newest development on this is today and the clutch pedal has gone ridiculously light! If you stamp on the clutch pedal with all your strength you might just be able to slam it into a gear but 9 times out of 10 it wont go into any gear :( Had to get towed home earlier and now its looking sorry for itself in my driveway :(
Any help much appreciated!
Ad
Post Thu Aug 04, 2011 10:33 pm
sounds like either your clutch slave or master cylinder had sh!t itself with plenty of warning along the way!
Check your carpet is dry below the clutch pedal, if its the master it can dump brake fluid all over you mats and carpet not good.
If its the slave then its bolted to the passenger side of the gearbox. Is there a fluid leak there? either way one is shot and its best to replace both at the same time.
Adams-Sideways
Post Thu Aug 04, 2011 10:51 pm
Cheers mate, how much is involved in replacing both?
Post Thu Aug 04, 2011 10:54 pm
its nothing major, the master can be a bit of a pain but bleeding/replacing are simple DIY really. No special tools needed.
Couple of hours if that should see it done
Adams-Sideways
Post Thu Aug 04, 2011 11:17 pm
Cheers mate, does seem to defo be the problem, i had puddles in both passenger and drivers footwells this week not to mention the fact the that the little clutch fluid resiviour under the bonnet always needs topping up. Are there any good guides on here for doing the master cylinder ?
Post Fri Aug 05, 2011 7:40 am
If you remove the under-dash panel and stick your head under the dash its quite easily visible and looks easy to get at.
I've got to do this on my car shortly.
Apparently you should always change the slave and master cylinders at the same time and bleed the whole lot through with new fluid.
Theyre not expensive - ECP, GSF or even Ebay - loads of new ones available for not much cash.
Change the Flexi rubber hose for a goodridge braided one while you're at it.
kman82
Post Fri Aug 05, 2011 4:16 pm
Sorry to hijack the thread but I've been putting this job off on mine for some time now but its got to a point where its thirst for clutch fluid is costing me dosh and a pain in the a&& to do every couple of days.
Capri_rob you mention using aftermarket master and slave cylinders, what is the general consensus for using these? Are they any good or is it bettter to shell out for BMW parts? Do you notice any difference in the feel of the clutch when completed?
Adams-Sideways
Post Fri Aug 05, 2011 8:23 pm
no worries mate, fire away as it will help us both. I inspected both cylinders today and both looked visibly ok although im told you cant tell when the slave is leaking as it can leak into the gearbox?
I bled the system and all is tip top fine now :) Will watch the level tho as im sure i will have to do the slave atleast soon. Didnt look too hard tho :)
Ad
