urgent spring help
jimbob29
Post Thu Aug 04, 2011 9:35 pm
drivers side spring has slipped anti clockwise spring pads are wet for some reason to and cant twist them back other way.can i jack up car and put some compressors on the spring and turn them back???
Post Thu Aug 04, 2011 10:35 pm
yes but i doubt spring clamps will fit enough to compress the spring to turn it. It might work, worth a try.
Have you checked the fluid hasn't come from the damper failing! or a brake fluid leak of some sort.
jimbob29
Post Thu Aug 04, 2011 11:23 pm
i hope it works is it bad to leave like that?its defiantly water havant a clue how it got ther tho
