AFM and Timing
CHR1S1990
Post Thu Aug 04, 2011 9:53 am
How much does the AFM flap affect the timing on an m20?
I want to replace my m30 AFM with a straight 80mm pipe. Im on LPG BTW, of which fuelling is controlled by another means so it is only ignition timing I am worried about. Note, I never run on petrol, though i could keep the AFM simply in the boot.
Any of you LPG guys ("flap opener" users?) experienced any drastic (detrimental) effects to timing with or without a functional AFM flap to measure load? Or does anybody have any motronic documentation i can have a rummage through.
cheers!
Post Thu Aug 04, 2011 10:02 am
I ran my red touring for a short while, right after I converted it, with a pin holding the flap open and can't remember any noticeable difference in performance.
Don't forget timing is way out when running LPG anyway. Needs more initial advance, with less total advance.
CHR1S1990
Post Thu Aug 04, 2011 10:08 am
Thanks Brian. Agreed it is already way out for LPG, I just dont want it to be even 'more' out removing the AFM altogether, if you understand my gibberish. At present it's just causing a restriction and unnecessary weight.
I'll get some 80mm pipe and give it a go then. Ive noticed a considerable difference in power by simply adding a 90deg silicone hose after the LPG carb and putting the cone filter behind the headlight so far.
Post Thu Aug 04, 2011 1:47 pm
I've never really thought through it, but it's possible that the timing is better suited to LPG without the AFM input!
CHR1S1990
Post Thu Aug 04, 2011 8:23 pm
That would be nice. Anyway, i removed the AFM and replaced it with a piece of 70mm pipe. Initial thoughts are wow, this sounds awesome. Then you realise it's lost a bit of low down grunt (which adds to the b20 problem as it is) but it does add some raw top end power. Man it screams at high revs! Coupled with the 6 branch, it's almost perfect (shy of ITBs...which are in the pipelines).
I think I'll be leaving the AFM out for now!
CHR1S1990
Post Tue Nov 01, 2011 3:30 pm
Update on this, shortly after removing the AFM i replaced it. Cold start timing was way off and it would run like a sack of crap/backfire on LPG. Need to sort my M30 AFM out though as the flap seems to be binding on the roof of the housing causing it to stick and backfire on mornings.
CHR1S1990
Post Tue Nov 01, 2011 4:18 pm
a question for you actually brian, i always start and run on LPG, and ive noticed that the engine hesitates and wants to misfire/backfire if you go above say 3K when the engine is stone cold. I used to put this down to a cold vap and lean running but since installing a wideband AFR gauge, the AFR sits nicely between 14 and 15 at these higher revs, so I assume it has something to do with the motronic timing when cold. It runs perfectly when warmed up, any chance of installing some sort of resistor on the coolant temp sensor wire to fool the ECU into thinking the engine is always warm? I never run on petrol so that shouldnt be such a problem, or perhaps make some sort of lpg switched relay and resistor?
e301988325i
Post Tue Nov 01, 2011 4:27 pm
Hi Chris,
How's things?
BMW bodged the temp sensor with a relay on occasion, I believe it was to cure hot starting trouble. No reason it couldn't be done vice versa, I fitted a hot start helper box to my E36 TDS, told the ECU the engine was cold when it was in fact hot.
The resistances are known for the blue temp sensor so one resistor of the hot value should easily 'trick' the ECU, leaving the dash gaug reading properly.
I expect that the trouble igniting the mixture when stone cold is down to the fact that LPG is more difficult to ignite. With a cold manifold and combustion chambers the charge is not being warmed.
Are you using/have you tried any of the 'LPG' plugs? I've been watching a £60 NGK iridium set for a year but havn't got around to buying them, currently using super fours as the standards didn't last.
I said:
e30topless said:
lock the wife in there
CHR1S1990
Post Tue Nov 01, 2011 4:40 pm
Hi Alex
not bad thanks, yourself? left the car alone for a while until recently, did you see the thread i posed up on the ITBs I made? Debating whether to sell them to fund a the stroker build or save up for MS to run the ITBs properly.
Funny, i was reading about that exact bodge recently, would be interesting to see if something could be worked.
Ive been mulling over the same set myself alex. The ones which last xxxxx miles? Quite hefty in price but similar £/mile i assume to the standard ones. Not tried them myself though no, Ive always used NGKBPR6ES, though i did try Bosch ones once and they were rubbish.
e301988325i
Post Tue Nov 01, 2011 4:46 pm
I'm ok. The list of things to do on the car is getting frightening though. We moved house and I now have space to work, trouble is I've had so many jobs to do since moving that I've not touched the E30 really, other than securing the first aid kit and warning triangle holder properly which took 5mins!!!
These plugs, dropped to £50, I would have tried them for that, super4's are £30.
http://www.ebay.co.uk/itm/180609678106? ... 1423.l2649
I said:
CHR1S1990
Post Tue Nov 01, 2011 5:55 pm
Congrats on the move. Always the case, no space lots of time or the complete opposite. Thats not a bad price actually, I might have to get a set if they last long enough!
Just taken the m30 AFM off and the flap is obviously slightly bent from a backfire causing it to slightly rub and sometimes stick on the housing causing me lots of grief, especially in the morning. I managed to bend it back (gritting my teeth bending cast alloy) enough to stop it touching and all is back to normal. Ill have a thorough read about the BMW bodge and try and do the opposite and report back.
Im trying to make sure I dont have problems this winter as I didnt have the BLOS last winter so in unknown waters atm. Ultimately this will all be useless as Ill be going over to MS, just deciding whether to get MS first or get this stroker built. Do you think the BLOS will be able to handle the extra CCs of a m20b28?
e301988325i
Post Tue Nov 01, 2011 6:02 pm
The BMW bodge, that was a relay triggered by the starter signal from the key and as soon as the key is turned back to 'run' the relay disengages giving the ECU accurate temp info. Maybe I'm wrong.
couple this:
http://www.ebay.co.uk/itm/QTY-2-10-watt ... 2308ce358c
with one of these either end
http://www.ebay.co.uk/itm/100-RED-2-8mm ... 43a6e08d18
and plug into the blue temp sensor socket:
I said:
Post Wed Nov 02, 2011 9:50 am
CHR1S1990 wrote:a question for you actually brian, i always start and run on LPG, and ive noticed that the engine hesitates and wants to misfire/backfire if you go above say 3K when the engine is stone cold. I used to put this down to a cold vap and lean running but since installing a wideband AFR gauge, the AFR sits nicely between 14 and 15 at these higher revs, so I assume it has something to do with the motronic timing when cold. It runs perfectly when warmed up, any chance of installing some sort of resistor on the coolant temp sensor wire to fool the ECU into thinking the engine is always warm? I never run on petrol so that shouldnt be such a problem, or perhaps make some sort of lpg switched relay and resistor?
Both the engines I run on multipoint LPG systems have resistors permanently connected across their coolant temp. sensors, so that the gas ECU switches over much earlier than it should. Like you, I find the engine is 'flat' for a while.
Propane boils at -42 degrees, and has a very high heat of vaporisation (R290 refrigerant gas is propane mix), so when you start a cold LPG car, there is plenty of heat in the coolant (-10 - +20 degrees normally) to provide enough vapour to start the car, but once it's running, and under load, the refrigeration effect of the liquid turning to vapour cools the vaporiser to around -42 faster than the engine 'coolant' can replenish the heat, and liquid propane gets through into the vapour lines and is fed into the engine, causing it to run rough, not because of a weak mixture, but because of a rich one. This probably alternates with no liquid at all getting through, and at those times the mixture will be extremely weak.
Maybe this is what your wideband sees - averaging out the wildly varying mixture, and recording gas that hasn't burnt, because it was still liquid in the cylinders.
On the other hand, your theory may have some truth in it!
If you want to experiment with resistors, you don't need anything like in that link. A 1/8W 330 ohm resistor, costing less than 1p is more than adequate. Pick up the temp. sensor wire in the loom under the dash, near the ECU plug, or connect a wire inside the plug itself, and connect the resistor between this wire and earth.
CHR1S1990
Post Wed Nov 02, 2011 1:12 pm
thanks for your input brian, i'll give it a try, and as always an interesting read. Do you happen to have any thorough documentation on motronic 1.3 by any chance?
e301988325i
Post Wed Nov 02, 2011 7:03 pm
Brian's right on the resistor values of course I got them mixed up.
Try this
http://www.e30zone.net/modules.php?name ... c&t=153524
I said:
e301988325i
Post Sun Nov 06, 2011 5:46 pm
Info at the bottom of this page ref the BMW relay bodge
http://www.e30zone.net/e30zonewiki/inde ... tart_Relay
Bloody cheap iridiums, will order 6, automatic postage discount
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0640995108
I said:
CHR1S1990
Post Sun Nov 20, 2011 2:42 pm
Brianmoooore wrote:A 1/8W 330 ohm resistor, costing less than 1p is more than adequate. Pick up the temp. sensor wire in the loom under the dash, near the ECU plug, or connect a wire inside the plug itself, and connect the resistor between this wire and earth.
cant seem to find the resistor on maplin, can anyone help?
http://www.maplin.co.uk/
im a bit of an amateur when it comes to component electronics so you'll have to bare with me here, im having difficulty understanding how to wire the resistor in? In the ECU plug?
thanks
CHR1S1990
Post Sun Nov 20, 2011 5:54 pm
just got back from maplin and the girl behind the counter has sold me a 3.57K resister :x
just checked my box and the closest resistor to 330oh is 511oh. Combined with the ~300oh resistance when the engine is warm would give ~200oh. I need to drive another 10miles tomorrow to go get the correct one (ill be taking my multimeter this time!), will a resistance as low as 200oh cause me any troubles? does motronic continue to effect the timing beyond this point?
forgot to mension ive no choice but to use this resistor until i get a new one tomorrow - my M30 AFM exploded today from a bit of heel&toe backfire action so Ive no AFM which will connect to the cylindrical BLOS, and last time I ran without an AFM it backfired like crap until it was warm.
CHR1S1990
Post Sun Nov 20, 2011 11:12 pm
Found some interesting info for those who are interested:
on motronic 1.3:
Limited Operating Strategy (LOS)
In the event of a serious fault in one or more of the sensors or their wiring circuits, Motronic will substitute a fixed default value in place of the defective sensor. This procedure is often termed limp home. A serious fault occurs when the signal from the sensor is outside of its normal operating parameters.
When operating in LOS the engine may actually run quite well with failure of one or more minor sensors. Since the substituted values are those of a hot engine, cold starting and running during the warm-up period may be less than satisfactory [EDIT:THIS IS WHAT IS EXPERIENCED RUNNING ON LPG WITH AFM REMOVED]. Also, failure of a major sensor, ie the AFS, will tend to make driving conditions less easy. Once the fault has cleared, Motronic will once more
accept the live signal from the sensor. The following LOS measures are taken in the event of a failure
Component/ Action
AFS [AFM]/ substitute values are calculated from the TS position. The load
signal is fixed to 6.0 ms and the ignition timing to 20° BTDC once
the TS contact is open.
ATS [AIR TEMP IN AFM]/ substitute value of 50° C . A code will not be set, and LOS will not
commence until a minimum of 3 minutes after engine start and the
engine idling for a minimum of 30 seconds.
CID sensor [on HT leads]/ injectors are pulsed simultaneously
CO pot/ substitute value of 2.77 volts
CTS [BLUE SENSOR]/ substitute value of 80° C if ATS value is greater than 20° .
if ATS value is less than 20° , substitute value of ATS value for first
three minutes after engine start-up .
OS [LAMBDA SENSOR]/ substitute value, open loop control
TS [TPS]/ substitute values, restricted engine operation
CHR1S1990
Post Mon Nov 21, 2011 10:23 pm
Feel like I'm talking to my self in this hole!
Anyway I shall proceed doing so.
Results from todays work:
[youtube][/youtube]
greasy roads=lots of wheelspin :D
I fitted the 511 Resistor yesterday and this morning I went for a run - same symptoms as last time I removed the AFM so I decided to plug the (albeit buggered) M30 AFM in and set it aside in the bay. This time the engine runs as it should hot and cold. When the AFM crapped its pants, theres no output voltage connection back to the ECU, so the only thing left working was the air temp sensor. So ive removed the sensor from the housing and mounted it in the air pipe (70mm drain pipe cut off in place of AFM winkeye ) and it seems to be running like it was with the AFM plugged in.
P.S. The sound is immense with the AFM removed, slight reduction in low down torque but it pulls much much stronger at the top end.
e301988325i
Post Tue Nov 22, 2011 7:05 am
it's not surprising you've needed to replace both the afm and air temp signal, the air temp defaults to 50c when removed which seems crazy IMHO. There's a good motronic write up stickied at the top of tech help. As we know lpg is tolerant of setup which is proving it's worth!
I said:
CHR1S1990
Post Tue Nov 22, 2011 4:53 pm
indeed it is alex.
i dont have the AFM plugged in now as it is buggered, just the temp sensor plugged into pins 1 and 4 of the AFM plug and seems to be running fine! ive got a spare m20b20 AFM im keeping in the boot incase it does want to see an output voltage from the AFM potentiometer, even if it is an "out of bound" value with not being in the path of airflow
