wiring in H.I.D
JAFF
hi all tonight "iv been" wiring up a set of plug and play H.I.D with clive (kingcruizer) but they flicker when they switch on i believe its due to the 10% wire that piggy backs from the head lights ,how can i cut this out to solve the problem ?
ali50ferrari
You cant neccessarily stop it but what you can do is remove the plug on the inner passenger wing, take off one side of the front grill passenger side and on the inner wing there is a small box looking thing with wires in the top and bottom disconnect the top or bottom and no more flicking on the dipped beam look just the side lights will come on, it isnt an issue with m.o.t either mine passed in late may with this same thing.
The preacher is pious lord, for he is scared of hell, where as me I sinned freely trusting in your mercy
It's normal for HIDs to give a bright flash when they are turned on, then come up to full brightness over a few seconds.
The flashing effect due to the dip dip driving light circuitry, if fitted, should only occur with the lighting switch in the first position. They should work properly with the switch fully out.
JAFF
thanks all !,its now sorted ,now iv just got to start putting the girl back together and get the paint work buffed up ,unfortunatly she wont be ready for pod but hopefully will be for gaydon
- E30 Zone Meets/Events Team
Jaff, POD happened a few weeks ago.
JAFF
no POD USC rav
JAFF wrote:no POD USC rav
