front controll arm bushes
jimbob29
after unscrewing the two bolts do you need a puller to remove the bracket and bush or do they simply pull of arm?can you get the brackets with bushes allready installed and do they simply push on arm or do you need a tool to put them back on arm?weres the best place to get them?
chips
- Was Pzero
A puller is handy to get the lollipop off the arm. Fairy liquid should helps things along. To get the bush out of the lollipop, I use a vice, a piece of tube I found which is roughly the same diameter as the lollipop, and one of the new bushes. Put the whole lot in a vice and you will be able to squeeze the old bush out and the new one in at the same time. Make sure the arrows are aligned first. To get the lollipop back onto the arm, use more fairly liquid and some elbow grease.
Best place for bushes is BMW. A lot of folk use the M3 offset bush instead.
For the sake of a couple of pints take the arms down to your local garage and get them to press the new bushes into the lollipops and onto the arms.
Several people on here reckon they can be put on with fairy liquid/silicone grease/gorilla strength - I tried for 2 hours on a saturday morning and got 1 halfway on before I Gave up and took the arms to my local garage and both were done in a matter of minutes.
As above the M3 Eccentric bushes are a common and worthwile upgrade - about £37 from BMW only.
chips
- Was Pzero
You're right, it's not easy. I think i rested the lollipop on top of a black and decker workmate type thing and then put all my weight on the control arm to push it down through the bush.capri_rob wrote:Several people on here reckon they can be put on with fairy liquid/silicone grease/gorilla strength - I tried for 2 hours on a saturday morning and got 1 halfway on before I Gave up and took the arms to my local garage and both were done in a matter of minutes.
I tried all manner of ways including making a puller with a threaded bar - none of it worked.
To do it properly without damaging the bush really you need a hydraulic press.
Pop the bush in the freezer and gently heat up the lolipop but be quick about it !
Wear gloves as well.
Not Marigolds either.lol
jimbob29
you can get new brackets with bushes allready installed from unipart for 30 pound each how easy are they to put back on the arms?just slide them on by hand and do up the two bolts no tool ect?if i decided to get m3 bushes do they go same way?no fiddling around to put them on because of the eccentric set up ect?will car need to be aligned after???
