getting steering wheel 100% straight
polsta
is there any easy way to get a steering wheel 100% straight ?
turkeysneck
Only with a four wheel alignment, even if the rear is non adjustable you still need the readings from the rear to get a straight wheel.
polsta
say again ? you mean like laser tracking ? get that done then do the wheel ? must be an easier way ?
i find it harder with my sport no PAS, than it was on my is with pas
turkeysneck
You can do it but the problem is it's not easy, it's very long winded. You can set the front toe with a couple of pieces of string but you'll find the wheel won't be straight. Before I got involved with alignment gear, the most accurate way and easiest I found was an adjustable bar, you drive the car up the road figure out where the wheel is situated then remember where it is and leave it in that position while you do the toe with the adjustable bar. Set the bar on the inside of the tyres or rims if they are straight then compare it with the rear of the wheel and make adjustments to get the required setting. You can get it very close with this method. Once you've got the required toe you still have the problem of the wheel offset. Then you turn the wheel into the correct position and figure out roughly how much you need to turn the adjustment to set it straight. Then you take the car up the road and see if you have improved it. If you have you need to keep doing this until you get it bang on. But of course once you've done that no doubt the toe will be out again so you have to re do the toe and repeat the whole process until the toe is correct and the wheel is straight. It's a major pain the balls but it is possible. I've done it this way a million times and I'm glad I don't do it this way anymore.
get the wheels aligned first to ensure there is the same amount of adjustment at both sides and the wheels are pointing dead ahead - then move the wheel a few splines if its not on dead straight.
I always find I have to keep the socket in the car drive it with the nut just nipped up and keep stopping to make a few adjustments until I get it spot on - only then tighten the nut fully and put the badge back in the wheel centre.
polsta
this is what ive been doing today, even for a few mins drove up a quiet long road without the nut oncapri_rob wrote: I always find I have to keep the socket in the car drive it with the nut just nipped up and keep stopping to make a few adjustments until I get it spot on - only then tighten the nut fully and put the badge back in the wheel centre.
turkeysneck
It's a miserable way and frustrating way to do it. You really need to pay someone to do it properly and compensate for the rear toe if it's non adjustable at the rear. It'll drive straight and not eat tyres then.
polsta
miserable i agree, but least its free !!!
how much would they charge ?
putting new wheels on this week, 15" , from 17" on the car, so might get it tracked also for good measure and make sure its all ok, so would it be done then ? is that what you mean get it tracked etc and 100% straight then just put the wheel on dead center ?
turkeysneck
Charges vary widely. I'd say you don't want to be paying more than £45.00 plus vat for a four wheel toe alignment (tracking) and that's laser gear.
That's the best time to do it when you've put new tyres on. The problem is once a tyre has started to wear uneven, even if you have it tracked the tyre will still carry on wearing uneven.
Not sure what you mean but if you take it somewhere to have it done make sure they compensate for any uneven toe readings on the rear, if the rear is standard and non adjustable. This is important to get the wheels straight and the car driving straight.
Ajsingh
Make sure all bushes and balljoints are in good condition.. This
Involves rear beam bushes
E30 Crazy!
