OBC Code
turkeysneck
Post Sun Jul 31, 2011 6:05 pm
Can anyone tell me about the OBC code, do I need to put in some sort of code when it's installed in the car ?
sideshowbob
Post Mon Aug 01, 2011 1:19 pm
My E30 doesn't have an OBC but my E24 does. If I rember it is the 13 buttion one from an '88 model. I have recently refurbished the interior and restored the body work.
Regarding the OBC the bulbs had burnt out so I took the computer out and replaced the bulbs in the light bar and re-installed the computer. Re programming it was abit haphazardas you have to push a bit of wire in a little indent to go from USA through metric to UK measurements.
The code button according to the OBC manual allows you to put in a 4 digit security code that has to be inputed as part of the starting proceedure. If I rember rightly the engine will turn over but not start if the incorrect or no code is put in.
As I have not attempted to input a code my engine and ignition all work on the key and I have decided never to use the code system as if it goes wrong I can't imagine how you would get round the problem.
Not sure if this helps
**BANNED**
Post Mon Aug 01, 2011 1:32 pm
sideshowbob wrote:My E30 doesn't have an OBC but my E24 does. If I rember it is the 13 buttion one from an '88 model. I have recently refurbished the interior and restored the body work.
OBC interupts the green(ign switch to coil)wire,so failing to imput the correct code does indeed allow the engine to crank(black/yellow!)but not start.
Dis-connect the battery and the OBC forgets what it has been told....
I do not use this 'feature' either,never tried it,probably will not work! I think the alarm/immobiliser part of the OBC setup is the box above the engine ECU,never tried it,but it may be possible to install the OBC without this box,and still get the 'usefull' bits?(time/date/consumption/outside temp)
Youth is wasted on the young.
Post Mon Aug 01, 2011 1:48 pm
The code can be any four digits you choose at random. Any four digits to set the 'code' immobiliser, and the same four to unset it.
Doesn't have to be the same four the next time you use it.
turkeysneck
Post Mon Aug 01, 2011 6:40 pm
So do I need to input a four digit code every time I go to start the car ?
Post Mon Aug 01, 2011 7:10 pm
turkeysneck wrote:So do I need to input a four digit code every time I go to start the car ?
No, once disarmed it stays disarmed, until you push the CODE button with the ignition switch in position 1.
turkeysneck
Post Mon Aug 01, 2011 7:12 pm
Ok thanks.
