I have a couple of tasks to undertake this weekend.
1st: try figure out why my electric mirrors aren't working in certain directions - I am struggling to find a diagram in the haynes manual for fuse box - 86 325i
2nd: the door on the drivers side has stopped locking (it's manual with key -no central) the key turns in the lock but the pin doesn't move and I'm forced to leave the car unlocked on the street
some tech help.
kunjani
I was in a hurry and forgot to add please - my appologies.
Tedswagon
Take door card off and it should be obvious. Lock mechanism operated by key is bolted to inside part of the door. A clean and lubricated should be enough. Fingers crossed.
Not sure about mirrors.
kunjani
Door card taken off, had A little fiddle with thew lock ( which I cant actually see as it's behind a little panel. gave it a blind clean and lube. EPIC FAIL!
the lock mechanism feels like it's turning fine but just is'nt pulling the pin down and the pin goes down fine when the door is closed.
I' give the lube some time to set in and have another crack tomorrow.
Also I notice I am missing loads of door card clips - does anybody know where to sorce them?
lamby
ebay for door clips,lock has prob had it mate mines same it will unlock but not lock,you will feel a u shape part in the corner and the lock engages this but aint got the strength to push/pull it so it slips in the lock.3 quid for 10 clips iirc
