Missing fuses?
MurphyE30
Post Thu Jul 28, 2011 8:34 pm
Looking in my fuse box it looks like theres quite afew missing and im not sure if im missing any that i should have.
can anyone advise me on what the missing ones are for? and if i need to put any in there?
here is a pic of my fuse box as it is now:
Post Thu Jul 28, 2011 8:49 pm
Print this off and compare the colours with the fuses you have fitted. Just #11 incorrect, as far as I can see: http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
You won't need fuses fitted for things your car doesn't have.
rrs
Post Thu Jul 28, 2011 9:22 pm
#10 is wrong according to the fuse box diagram, should be no 20A fuses in an e30 fuse box I believe
Post Thu Jul 28, 2011 10:33 pm
rrs wrote:#10 is wrong according to the fuse box diagram, should be no 20A fuses in an e30 fuse box I believe
You are indeed correct! I only looked at the small pic as it appears in the thread, and thought #10 looked brown, which would be the correct 7.5A. Now that I've 'clicked' on the pic. and seen it full size, I can clearly see that it's marked 20A.
Needs to be changed ASAP.
#28 is wrong as well.
MurphyE30
Post Thu Jul 28, 2011 10:36 pm
thanks for the help guys. i will take that 20A fuse out in the morning and change for a 7.5A
will try and get a print out of the diagram and have a check through them
