Brakes lack bite
Mike316
Post Wed Jul 27, 2011 3:34 pm
My 1993 316i Touring's brakes lack bite if I brake hard. I can't lock up or bring in the ABS even in the wet. In normal use, braking feels fine. Good pedal pressure, no pulling to side, no loss of fluid. In last 4000 miles I've had four new discs, all new pads and a fluid change this week (when it also passed its MOT). All parts are standard BMW. All done by my regular BMW specialist who is usually very good but he reckons they're 'alright'. I'm used to older BMWs - I've had another E30, an E28 and an E24 and they all stopped much quicker in an emergency!
Any thoughts on the likely problem would be really appreciated before I take it back (or somewhere else).
Thanks, Mike
1986 E30 316 4-Door Saloon (Sold)
1993 E30 316i Touring (Sold)
1989 E30 320i Auto Convertible
Post Wed Jul 27, 2011 4:40 pm
If it passed the MOT with no comment about braking efficiency there shouldnt be anything to worry about.
You could try tweaking the bar that runs between the brake pedal and servo to bring the pedal up a bit - this can improve braking "feel".
Did you use good quality discs and pads when they were changed ?
You could also try fitting braided hoses.
mattycoops43
Post Wed Jul 27, 2011 4:57 pm
Vacuum servo I would guess, unlike modern cars, if you lose some vacuum due to a perished hose, the brakes still work, they are just crap. I lost a vac pump on a mondeo and I completely lost all brakes! I had a vacuum leak on my e30 and the brakes worked ok when driving, but when you pulled up, they wouldn't lock the wheels if you stamped on the pedal.
I took off all my pipes, removed the ends which had gone hard and replaced all the jubilee clips and they have been fine since.
1990 325i se "weinrot"-How did they know?
Mike316
Post Thu Jul 28, 2011 12:29 am
Thanks for these suggestions. The pads and discs were good original equipment quality, so they shouldn't be the problem. The vacuum leak might be a possiblilty worth a check, though. Would that not affect engine idling as well? It idles very smoothly - better then my E24 straight 6!
Could it be calipers beginning to seize, perhaps? I have just read about that being the cause of a similar issue on an E24 forum. I was surprised it sailed through MOT without comment. Let's just say I'm keeping a much bigger distance behind the vehicle in front...
Thanks,
Mike.
mattycoops43
Post Thu Jul 28, 2011 8:53 am
Mine idles fine with a small vacuum leak, I think the leak was too far away from the manifold for it to make a difference. if it was a caliper, I think you would find it pulling to one side under braking. It sounds like it has to be something affecting the whole system. Symptoms are exactly like mine was.
Mike316
Post Thu Jul 28, 2011 11:00 pm
Yes - that makes sense. I think you could well be right. I'll go over the vacuum servo and its pipes and see if that improves it.
Thanks again.
Mike
HairyScreech
Post Thu Jul 28, 2011 11:38 pm
i always find mine lacks initial bite, making you less confident on the breaks, but when i have stood on them in anger then they pull up lovely, always has been the case.
are you sure its not just the usual e30 breaks being a bit mushy and lacking initial bite?
Mike316
Post Fri Jul 29, 2011 12:18 am
I know what you mean but I don't think so. I'm light on brake use usually but it doesn't pull up sharply if I brake hard. It's never been as good at stopping as a 1986 E30 316i saloon I had.
Mike
