Testing ABS sensors
Jozi
Is there anyway to test if a ABS sensor is working as it should?
You can check the DC resistance of each one, which should all be similar, and an AC voltmeter will give a reading if connected to a sensor and the relevant wheel spun. Again, the readings from each wheel should be similar.
Front sensors are handed, and will give a very low output if fitted on the wrong sides. (Or is it the rears??)
Jozi
Thanks Brian. Front and rear should be the same I guess? Checking with the AC voltmeter will have to wait until the bearing goes back on.
ABS ECU looks for the frequency of the sensor signals rather than the voltage, but the outputs should all be similar at the same wheel rotational speed.
monkey
it is the front ones that are handed and my sensors where about 1000 ohms when i tested themBrianmoooore wrote:You can check the DC resistance of each one, which should all be similar, and an AC voltmeter will give a reading if connected to a sensor and the relevant wheel spun. Again, the readings from each wheel should be similar.
Jozi
Is there any markings on the front sensors to say which goes where? I took it as them being both the same either side up front.
Monkey, was that hem tested while spinning the rings?
- **BANNED**
Seem to remember that the case or the bracket has l/h or r/h stamped on.
I got lucky when I damaged a sensor wire swapping a suspension leg,first one I found in the parts pile was the correct side!
It was much later that I discovered just how lucky I was.....
Youth is wasted on the young.
Jozi
I found the tiniest little R on one sensor, the other was a bit scratched but I think I could just see a L
Stuck the multi meter on them both and got a little over 1000ohms for both sensors. Will have to test them with the hub before I'll know for certain if I didnt damage them though, the tip of the sensor isn't perfectly flat anymore. I might get lucky and have not damaged them
HairyScreech
one other thing to do, if your worried they are withing electrical spec but not reading, is just look for a change in resistance as you turn the wheel or wave a bit of steel V close to them.
