when driving the sport the other day i discoverd it would only really drive at WOT or a tiny bit of throttle nothing inbetween at 1/4 throttle upto 3/4 throttle there was nothing, prehaps the odd puff and bang now and again. it was if i took my foot completly off the accelarator.
what does that sound like???
also are 325i AFMs all interchangable.
it drives differently to before i done the motronic 1.3 conversion, when i was running motronic 1.0 it missfired throughout the rev range. i feel like i removed the original problem and have ended up with a new problem.
thanks
325i sport, will only drive with a little throttle or WOT
mrLEE30
The TPS or throttle position sensor would be my first port of call, especially as it only works on idle and very low throttle, and WOT.
will try a new one see if i have any luck with that
Grrrmachine
- E30 Zone Wiki / Team Member
Take the old one off first and clean it out with Carb or Contact Cleaner. There's also a method of drilling a small hole in the plastic to let oil drain out of it, so that it doesn't get gummed up in the future.
Fix vs Replace, every time.
mrLEE30
If you have multi meter you can test the TPS.
Just bought a new one
mrLEE30
What a meter or an TPS?
sean_318i
I would try the Air flow meter first.
The engines ecu calculates a load signal for idle based primarily on the throttle position switch, if the car runs ok at idle the switch is probably ok.
The ecu calculates the load signal for part throttle openings based on the airflow meter voltage, if the car runs bad here the air flow meter is a likely candidate.
The full load wide open throttle signal is taken from the second set of throttle position switch contacts, in this case the airflow meters output is completely ignored, the car should run ok here too with a bad air flowmeter or with it disconnected.
Of course you may have a different set of faults but my advise would be to borrow a mates known good AFM to try.
Hth Sean
Hth Sean
