Rear fog light wiring diagrams need help with retrofit.
keskinKT4
Post Mon Jul 25, 2011 1:26 pm
Hi All ,
I'm fitting rear foglights to my E30 , it came from Japan and never had em fitted from new ,its an 88 Euro spec M3.
I need em to pass the mot.
I want to install them as they would have come from the factory .
I have the fog light switch and rear bulb holders which include a provision for fog lights .
I had a look in a manual and the wiring diagram in it doesn't seem to show the k9 relay so it confused me a bit.In that diagram the rear fog switch item 21 has a grey/violet wire going to the front fogs items 7 and 8 and the instrument cluster and a yellow/black wire going through fuse 15 to the low beam relay k4 and the front foglight relay k8. No mention of k9 relay or rear fog light bulbs at all.
(diagram below)
I have looked and there are no wires in the fuse box where relay k9(turns off rear fogs when headlights are on high beam) should be and no wires for rear fogs behind the dash in the fog light switch connector.There is no wire going to fuse 15 either.
There is a red foglight indicator in the instrument cluster but it has no bulb fitted.
I need the the diagrams for the REAR fog light circuit, the REAR fog light indicator light (instrument cluster) circuit, FUSE 15, K4 and the K9 relays.
All help appreciated.
Cheers.
E30 M3 Zinnober , anthracite uberkaro, BBS RS, Stock 200hp, E28 M5 Diamond Schwarz , standard car.
