MAF or Idle Valve???? HELP.
325isparda
Post Mon Jul 25, 2011 11:20 am
I have just got he bmw up and running and back on the road, but coming acros a couple of problems whic can be expected.
When the car is running and going along it is fine but when you come to a stand still and sit on tick over the engine chugs and does not idle very confortably :(
Im worried that it may be the MAF only because when you sit on tick over and disconnect the wiringfrom the MAF, the car idles like a dream.
I was wonderin whether anyone has been throuhg this or knows of how to rectify this problem any advice would be much appreciated :)
Thanks all.
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Jul 25, 2011 6:03 pm
E30s have AFM, not MAF. Not being picky, but it might help your search results if searching for advice on how to fix air-related issues.
More likely is that it's the Throttle Position Switch (TPS) or Idle Control Valve (ICV). Both can become sticky and gummed up, and a good blast with Carb Cleaner spray can do wonders for lumpy idles.
Another issue is a small air leak somewhere in the rubber pipework. Spraying WD40 around the hoses while idling, and listening for a change in engine note, will tell you if the car is sucking in air through a gap.
After that, AFM. Still, use the Search tool. If your car is the 325 in your picture, then rough idle is a very very common complaint with these engines, and has been covered a thousand times on this forum.
xr666
Post Mon Jul 25, 2011 10:16 pm
check clean your ICV with some carb cleaner
Davies31
Post Tue Jul 26, 2011 11:59 pm
Yep. Clean the ICV with carb cleaner as a start.
Nope. Spraying WD40 around the hoses won't produce a change in engine note. Lynx body spray would be better or any other cheap spray with propellant. If you have an air leak on the intake side there will usually be an accompanying noise. Like a whistle. Evident at idle but not when under load (pulling off/accelerating etc). Due to the vacuum pressure at idle.
I have just spent three weeks and ££'s changing hoses, jubilee clips, inlet manifold gaskets to eliminate my vacuum leak.
grantorino
Post Wed Jul 27, 2011 7:21 pm
Remove the rubber boot between the AFM and throttle body and stretch it out to verify no cracks or splits in the boot. If OK, clean the throttle blade with throttle body cleaner and an old toothbrush. Then clean the ICV with the same cleanser.
1986 325 ES stick shift 137,000 miles, 1973 Mercedes 280C
