Auto to manual conversion?
m_jermyn
Post Mon Jul 25, 2011 9:28 am
How hard is it to convert a 325i slushbox over to a manual?
I assume all the whole are present in the shell so there would not need to be any cutting or drilling.
Is it just a matter of getting a manual box and clutch, flywheel, peddle box, slave cylinder, master cylinder and maybe a manual radiator?
Maybe a manual ECU too?
Then fitting it all up..
Post Mon Jul 25, 2011 9:32 am
Simple enough job, but a fair bit of work, involving humping heavy bits of metal into place.
Radiator and ECU can stay.
Only bit that won't be present on your car is the mounting bracket for the clutch fluid reservoir.
Duke137
Post Mon Jul 25, 2011 9:41 am
Don't forget the clutch pipe across the bulkhead, it's easy to forget that when getting the parts together!
m_jermyn
Post Mon Jul 25, 2011 9:42 am
Wow sounds pretty easy then thanks Brian...
Took my brother for a spin in my car the other day and now he wants one too..
Found a minty high specked 325i auto...
Thinking might build another motor and do the conversion at the same time.
