Alternator Q... possible problem....
miniblob
Post Sun Jul 24, 2011 6:37 pm
Right, still got an electrical prob of some kind on my 327 touring.
Everything has been checked and changed and more and it still has a few people stumped!!!!!!!!
So, quick questions for today about the alternator....
Main thing i want to know is - with the engine running and nothing connected to the alternator, what should I see when i put a meter between the alt terminal and earth???
Should it show 14.4v or is it not that simple?
I'm seeing just over 1v!!!!!!!!
Battery was showing 12.6v before running the engine, and with everything connected and running it shows 13.6v, but it's not charging!!!
(new battery, all connections/earths checked, cleaned, reseated, blah blah).
Is there anywhere you can buy new brush packs / regulators for these now??? Euros don't sell them - are they available from BMW?
Even though the ones in there look reasonable and i've tried another old set!
Can there really be an internal problem with one of these alts?
It's not noisy at all and i have tried an alt that came from another car which i never had a prob with!
I'm getting really sick of this problem now - does anyone know a good auto electrician near Croydon - preferably someone mobile who can come to me?????
327 Touring with bass!!!
grantorino
Post Mon Jul 25, 2011 12:13 am
Not knowing what year your car is, my guess is the battery light in the cluster can be burnt out. 86 and prior years require that bulb to work to energize the voltage regulator. With key on, car off, does the battery light illuminate? If not replace bulb.
1986 325 ES stick shift 137,000 miles, 1973 Mercedes 280C
Post Mon Jul 25, 2011 12:28 am
you need to fit a new regulator and it will be sorted, with everything connected does your battery light come on the dash when ignition is in position 2?
miniblob
Post Mon Jul 25, 2011 1:12 am
Think the year is 1990ish (think it was on a H plate originally!)
Battery light on the dash comes on and goes off as it should!!!
Can a new regulator be got from anywhere??? It's part of the brush pack isn't it?
I have swapped the whole alt (with brush pack/regulator and suppressor) for one that came off an old breaker that I never had any probs with, so find it unlikely to be that, but i'm not ruling it out!
Does anyone know what output I should expect to see from the alt with the engine running and nothing connected???
grantorino
Post Mon Jul 25, 2011 3:05 am
By nothing connected you mean no items turned on? If so, you should see not quite 13 volts at the battery with car off. Once started you should see a little over 14 volts maximum. An amp output or load test is the ideal test. If your alternator is rated at say, 50 AMP's then under load it should get very close to that number. A shop can perform a load test very easily.
grantorino
Post Mon Jul 25, 2011 3:14 am
The alternator MUST have the 12 volt lead connected in order to produce voltage. You cannot test an alternators output with its wiring disconnected. If the battery shows 12.6 and once started, it shows 13.6, its charging but weakly. And it might only be 13.6 if the battery is fully charged. A quick and dirty way to verify any charge output from an alternator is to touch something metal to the rear center bearing on the alt. with the engine running. If the center bearing is magnetized, its charging.
miniblob
Post Mon Jul 25, 2011 12:51 pm
grantorino wrote:The alternator MUST have the 12 volt lead connected in order to produce voltage. You cannot test an alternators output with its wiring disconnected. If the battery shows 12.6 and once started, it shows 13.6, its charging but weakly. And it might only be 13.6 if the battery is fully charged. A quick and dirty way to verify any charge output from an alternator is to touch something metal to the rear center bearing on the alt. with the engine running. If the center bearing is magnetized, its charging.
Thanks grantorino - that's what i wanted to check!!
Pretty much what i thought, but someone said to give it a try!!
