this one is annoying, i linked the pin to chassis on the plug and temp guage didnt go to hot, so i took clocks out and brass nut is secure, the guage works kind of, it is where it should be with engine off, and with engine on it sits just above white line in the blue (cold) section and dont move, if i use indicators or brakes etc it dips down a little, enough so its noticable =/ so i guess wiring is ok, any ideas???? before i buy a new guage and prob find thats not the problem either?
thanks
oil temp guage problems
LLamaFarm
oh while on the subject of clock area, there was a bulb missing for brake pads low, should this be there on a 320i se model, the engine is a b25 with the wiring loom so gets confusing what should be there and not.
I think you mean coolant temp not oil temp, sounds like a bad connection somewhere
All E30s should have a pad warning bulb fitted. Finding it missing doesn't bode well for the condition of the rest of the car, as bodges like this indicate that the previous owner may not have been too fussed about proper servicing in general.
Do the service indicator lights work properly?
LLamaFarm
yea iv just been checking all the other sensors, i have checked the sensor on the pads and it does work i just dont know why the bulb was missing, i found a spare hidden behind the clocks when rumaging around maybe the same one that came out, i did take it out without removing steering wheel maybe it came out when sliding clocks forward??
im quite happy today as iv fixed the problems i found with it
, i think the previous owner looked after it, and spent alot of money fixing stuff, (receipts) and he was quite honest when i bought it pointing out faults rather than hiding them.
yea the service indicator lights work, everything works now im amazed lol
so heres update for crappy coolant temp incase anyone else has simelar faults, i thought just on the off chance maybe its wired wrong, well turns out it was, should have been the other pin on the plug connected to gauge so if symptoms above, check both pins to chassis see which one its meant to be, Red/brown on mine
Pad light bulb has its connections internally in the cluster. If you've found one on flying leads, then maybe that's an ABS warning light, which will be a whole new can of worms!LLamaFarm wrote: i found a spare hidden behind the clocks when rumaging around maybe the same one that came out, i did take it out without removing steering wheel maybe it came out when sliding clocks forward??
You've lost me here. How can it be wired wrong - the sensor plug's not reversible.so heres update for crappy coolant temp incase anyone else has simelar faults, i thought just on the off chance maybe its wired wrong, well turns out it was, should have been the other pin on the plug connected to gauge so if symptoms above, check both pins to chassis see which one its meant to be, Red/brown on mine
LLamaFarm
i know its not reversible, believe me i tried doing that to sort it, all i know is that it works with the other wire connected, i swapped the pins over in the brown plug and hey presto a loverly working temp gauge.
also continuity check to clocks the purple one isnt connected to anything, (well it is but solder track goes nowhere)
nah i resolderd it back onto the board i used to play about with electronics many moons ago so got track cutters and joints in a box in garage. theres no evidence of anything being solderd on flying leads anywhere, abs works fine
So the gauge hasn't worked since it left the factory?
LLamaFarm
no idea didnt work when i got the car, works now
