Can i add a button to operate ALL electric windows together?
Vincenzo
Post Sat Jul 23, 2011 10:18 am
Hi
I am about to buy another E30 Convertible and was wondering, can i add a button, as per the E36, which will operate ALL 4 electric windows at the same time? This function is particularly useful when the hood is down.
Any help and advice, particularly with fitting, would be useful.
Many thanks
threelander
Post Sat Jul 23, 2011 10:27 am
i,m sure it could be done with a little electrical know how
Andy325i
Post Sat Jul 23, 2011 10:28 am
Sure you can, but not sure all 4 windows will operate at the same speed, so thus there will be load on some while they are stopped and others are still in travel?
Interesting though
Andy
Post Sat Jul 23, 2011 10:40 am
Quite simple electrically, by adding a change over switch in the common earth wires from the switches, but the supply will need beefing up to contend with the current load, and the thermal cut is also likely to cause cause problems.
Vincenzo
Post Sat Jul 23, 2011 11:11 am
Brianmoooore wrote:Quite simple electrically, by adding a change over switch in the common earth wires from the switches, but the supply will need beefing up to contend with the current load, and the thermal cut is also likely to cause cause problems.
Ultimately i guess if we are talking about beefing the supply, this is a job for a vehicle electrician (as i would have no idea where to start or what to use!)?
Any ideas where i would be able to get a suitable switch and are there any kind of cut outs already hidden in the console for this sort of thing?
Post Sat Jul 23, 2011 1:51 pm
There is a thermal cut out already on the centre console, or on the dash of older cars, but it's only suitable for one window at a time. You'd need one for each window ideally.
Note 'total closure' was an option when E30s were new.
Vincenzo
Post Sat Jul 23, 2011 3:22 pm
Possibly crossed wires here, i mean a "cut-out" as in somewhere to fit the switch?
BadDave
Post Sun Jul 24, 2011 6:49 am
A pair of Meta 8 window closure modules could be used to do what you're after.
1 Meta 8 can close 2 windows and converts them to "one touch"closure via a small switch.
I use these on the Touring total closure setup
Fitting a pr would enable closure of all 4 windows.
If you wire then into the "door lock pulse" for the cental locking, they'll all close automatically when you lock the car with either the key or alarm remote.
Alternatively. you could use a 4window remote closure module from ebay(£20) or such like and fedd +12v to the lock pulse input via a momentary push button(Maplins) mounted somewhere on the centre console.
Both of these options would only close all 4 at the same time,you'd still need to lower them individually
