Hi Everyone,
I just picked up an M52 B28 E30 today, once I got home and parked up a load of smoke came out of the engine bay.
This happened when I had the steering on full lock.
A small whining noise comes and goes now when I steer almost upto full lock and stays there for a while.
What can it be... Please help
Smoking Power Steering Pump in my M52
Probably the belt slipping.
Steering should never be held on full lock if at all possible. It sends the pressure in the rack supply pipe through the roof.
Bela
Cheers Brian,
Found the problem.
A washer is leaking between the steering rack and pump.
Need to order it now, wonder what part number.
Found the problem.
