auto gearbox problem on 93 318i
geoffsdad
Post Fri Jul 22, 2011 8:08 pm
Can anyone advise what may be the problem , car starts ok in the morning, but when drive is selected nothing happens unless you rev the engine, then a whiring noise and drive is engaged, proceed to drive the car but it wont change gear unless on full throttle then it changes, after that the gearbox changes up and down no problem
for the rest of the day after stopping and starting but the problem is there again in the morning after standing all night.
The gearbox oil filter and oil have apparently been recently changed , it seems that something gets stuck over night.
i have just taken possesion of the car knowing the fault.
Any help would be welcome.
Car is one owner from new and moderate mileage on 87,000
fixedwheelnut
Post Fri Jul 22, 2011 9:27 pm
I would start by checking the Autobox oil level is correct, so many people under or overfill them, it sounds like a classic low oil level.
Hot engine at idle speed in park on level ground the ATF level should be between the two marks on the dipstick.
Andyboy
Alpina Colada
Post Tue Jul 26, 2011 5:41 pm
These are the exact symptoms of a sticking governor - I had it on an E23 728i once. If you have somewhere utterly clean to work, you can replace it after dropping the prop and removing the rear gearbox housing but in the end, a good used gearbox would be a better bet.
This is a good link -
http://www.cowdery.org.uk/zf.php
