steering clunk
jimbob29
when stationary and gently moving steering wheel left to right it clunks?this is non power steering model!thers no play in front wheels either?can some one list likely suspects before taking it garage cheers...
grantorino
Assuming the steering rack is bolted down tightly on the frame, I would check the steering column U joint at the base of the column where it passes thru the bulk head.
1986 325 ES stick shift 137,000 miles, 1973 Mercedes 280C
