320 engine ticking noise
cherryredbenj11
Post Thu Jul 21, 2011 2:39 pm
Hi im new to the e30 scene so this is probably a question. I have a 320 ise, the engine has a ticking noise sounds like the injectors but could it be the tappets, is there anyway to solve this or is it just the way these engines are.
**BANNED**
Post Thu Jul 21, 2011 2:53 pm
These engines run better with a slightly wider tappet clearance,pull the cover off and set to .25/30mm,closer setting is standard,I run at .28mm.
Injectors do tick a bit,have a look in the traders forum,there's a guy there who will clean,service and re-build by post at a sensible cost.
Youth is wasted on the young.
cherryredbenj11
Post Thu Jul 21, 2011 3:17 pm
0.28mm?
nas786
Post Mon Sep 17, 2012 5:21 pm
Im confused wat to do hav the same problem
, to run a bigger clearence or smaller??
scjimbo
Post Mon Sep 17, 2012 5:24 pm
nas786 wrote:Im confused wat to do hav the same problem
You have to find the source of the clicking first
nas786
Post Mon Sep 17, 2012 7:41 pm
Well im sure its the tappets, but ive re adjusted them with a tighter drag on 0.10 and now te engine is idling rougher at low revs when u start up :(
How do u stopt the injectors from clicking if its that?
SGP
Post Tue Sep 18, 2012 8:56 pm
You can't. The sound is a feature of m20s. (to put it bluntly)
If it ain't broke..
Fix it till it is :)
nas786
Post Wed Sep 19, 2012 11:15 am
Lol brilliant! I think im gonna adjust to a bigger clearance today as its tapping harder n louder now
kam-325i
Post Wed Sep 19, 2012 12:45 pm
Also check the exhaust manifold nuts on cylinder 6, this can produce a ticking sound with a slight leak.
