Wouldn't the paint break down over time and cause bolts to be under tightened? Or worse, come lose.
Another example being my camber/toe tabs on the rear beam, the eccentric bolts have already cracked some paint because it's so tight. I imagine after some adjustment of them even more paint will come of.
Same with the mounting surface on the callipers, if the paint started cracking there the bolts holding the callipers could come lose?
Might be thinking it through a little much but I'd hate to have to take every bolt of the car again and sand all mounting surface afterwards.
How bad an idea of me was it to paint the wheel mounting surface of the bubs
