My brake light indicator on the warning panel keeps coming on, usually five or ten minutes into a journey. When first setting off it goes out normally when you tap the brake. I've checked the brake lights when the indicator is lit and they are both on.
Is this a problem with a bulb or two not being the correct size/wattage/ampage? Or is it more likely a problem with the warning light unit itself?
Mike
Brake Warning Light Problem.
Zetecvan
It only takes a brake light malfunction for a fraction of a second to put the warning light on, and then it will stay on until reset by turning off the ignition, so the chances are it's doing its job.
Get someone to follow you when you drive, to report if there is anything happening that shouldn't be.
Is the pull rod across the car adjusted for the correct pedal height?
Zetecvan
No idea...! I'll have to check...Brianmoooore wrote: Is the pull rod across the car adjusted for the correct pedal height?
