Another temp guage question
m8782538
Post Wed Jul 20, 2011 11:44 am
I will try and keep this as short as possible.
1987 316i M10 Inj
When i first started the car the thermostat was stuck and after about 10-20 secs the temp guage showed as hot (as far into the red as it could go).
Now the needle doesn't even move. I am going to replace the thermostat when one is back in stock, is this likely to be the temp sender (brown sensor) or the nut on the back of the cluster?
I have repared the wires going to the brown and blue sensors as a rabbit had chewed them through, all fuses and relays are fine.
Any thoughts?
**BANNED**
Post Wed Jul 20, 2011 12:56 pm
It could br either!
Brown sensor is a five minute swap,removing the cluster and tightening the nut will take half an hour but cost nothing.....
Youth is wasted on the young.
m8782538
Post Wed Jul 20, 2011 1:12 pm
True. Brown sensor it about £12 i think. fun part about the cluster is taking the wheel off etc, plus i want to change over the speedo anyway, but was going to do that later down the line. may have to set some time aside to check the cluster.
Do you have to remove the under dash panel to remove the steering columb surround to get at the cluster? I know wheel off and under dash trim but not sure about the rest of it.
**BANNED**
Post Wed Jul 20, 2011 1:32 pm
http://www.e30zone.net/e30zonewiki/inde ... eplacement
I always remove the steery wheel,just one nut,and it makes the job so much easier,but it can be done with it in place.
Steering column suround is not disturbed.
clarko74
Post Wed Jul 20, 2011 2:19 pm
I leave the steering wheel on, it's not too tricky to slide the cluster out around it.
You can test the gauge using this method:
Brianmoooore wrote:Unplug the 20 pin C101 engine loom plug, right next to the fusebox. Identify pin 4 (brown/purple wire if you look under the rubber boot).
Use a piece of wire to earth this pin on the side that goes to the fusebox.
If you switch the ignition on, the gauge should go to full hot.
I also did the same test at the sensor plug to test the gauge and wiring.
clarko74
m8782538
thanks daimlerman, i know about the steering wheel just not about the column cowl and under column panel (since mine seems one of the few cars that still has this, despite it being loose and sagging a bit as it needs securing back in place).
