i basically hit a kerb a while back, it was a decent smack, I snapped the control arm from the centre joint clean in half, and ripped the arb from its bracket, and damaged the rack,and the 17" alloy also got pushed back into th wing which creased it inwards,
when i opened the door after there was a loud creak because the wing was touching the door,
i now have a problem with the door it doesnt close properly, if i look up in the corner theres a pretty big panel gap which lets in rain the inner door sills are usually filled with water and puddles...
the line on the outside doesnt seem to of moved, it looks the same at the top and width...
but any idea as to how i can rectify this? im thinking to buy some foam strips and line up the door temporarily to stop rain and motorway noise levels.. as is pretty loud on the freeway
any chassis/ bodywork distortion specialists here door prob
m_jermyn
Mate you have bent something considerably.. Does the swage line match up down the side of the car? Quarter to door and door to wing.
A pIcture paints a thousand words..
Sounds like you have bent the hing pilar..
Easy fix at your local panel shop but a little complicated for DIY. it involves removing the door, pulling the hing and trial fitting over and over to get it to fit again.
