After two years standing finally getting the sport out but..
Ben5732
Post Tue Jul 19, 2011 7:56 pm
Hey all, been ages since ive been on this forum. Had my 325i sport parked up for just under 2 years finally getting around to getting her back on the road.... Just came accross an issue however.... ive lost the damn key.... ive still got the immobiliser thing so that wont be an issue. Any idea if you can get a replacement key off BMW or anything without having to change all the locks or having the original key? Got all the documents etc in the house so have no problem prooving the vehicle is mine.
Cheers/ :D
beemerbird
Post Tue Jul 19, 2011 8:01 pm
Yes you can get a new key from BMW so long as you have identification for yourself and the car.
Ben5732
Post Tue Jul 19, 2011 8:04 pm
Perfect, cheers :)
Jim320i
E30 Zone News / COTM Team
Post Tue Jul 19, 2011 8:13 pm
Also, aslong as its the original keys still with it! If they have been replaced in the past and not by BMW then you wont be able to get the same set... I over heard someone elses conversation when last in there.
Ben5732
Post Sat Nov 12, 2011 12:27 am
Bit of a bump from ages ago sorry :)
Managed to get the car out for a few days in the summer which was a blast considering she had been stood up for two years n had no issues getting through the MOT other than having to borrow a friends exhaust for it.....
Anyway..... Left her standing again and now stuck with an issue.... Last time to get her started after lots of frantic searching i found a small bmw key fob which after using it thanks to the AA man connecting it to the battery with some wires managed to unengage the immobliser..... Now we run into another issue.... As the winter is coming and i want to be able to go the 24 hours of le mans next year i have a fair bit of work to do to make sure she is ready for it.... of course during this time the battery has gone flat but well..... Ive lost the fob!!
As far as im aware its a normal standard BMW alarm immobiliser fob with nothing fancy on it just beep the car unlocks and go.... Is there a way past this at all without another nice expensive trip to the BMW garage?
Ive read somewhere that on the service cap thing that if i bridge two of the connections it should bypass the immobiliser and she will fire right on up. Is this correct? Cheers and sorry for the old thread.
Ben5732
Post Thu Nov 17, 2011 12:47 am
Yeh you aint kidding ><.... Moved twice in the last year so everythings been up the wall really..
Post Thu Nov 17, 2011 8:59 am
Piece of wire from the battery + phantom terminal on the bulkhead to the ignition coil + terminal to switch the ignition on, and 11 to 14 on the diagnostic socket to work the starter motor. That's how secure the standard (and most aftermarket immobilisers) are!
For a more convenient and permanent solution, you need to remove the panel above the glovebox and look for interruptions in plain green and black/yellow wires.
