my mpg has dropped from around low 20s to about low 10ns recently im allways very busy and need my car so ive been putting it off, started it this morning after 3 days the petrol fumes were so strong it was unbelievable!
I had a look around and checked the inlet manifold fuuuk me the petrol was literally spurting out like dribbling excessively a huge puddle in around that area it was dripping down on to the floor!
ive never really noticed this before as ive never checked immediately after driving from cold, I suppose the petrol evaporates from the heat after a little while as 15 minutes later you coudnt see any trace however the smell was still there,
i suppose its one of the pipes around that area i need to get it off friday and have a look,
but yeah if you smell petrol and you got shit mpg, check the inlet manifold at the back of the engine, start up your m40 in the morning after cold and youl see what im going on about...
if anyone with an m40 has shit mpg and smell of petrol chek
gnrsoul
prob most likey the hoses there is two hoses you can see from the n/s the others are under the inlet i would check them out had the same problem just not as bad replaced them and as good as new
and i would say that i would not be drivin the car if the fuel is leaking in the engine bay, this could/or most likey go on fire the vapors will cose a fire does not need at lot to set it off
This is quite common on M40 engines - the two hoses run in a hostile enviroment for rubber.
Take the top half of the inlet manifold off for access.
bmw9818
yeah its dripping out from one of the hoses right under the inlet, would anyone know the size/width of the hose saves me cycling it to the parts store....
gnrsoul
not sure mate its only £3 from bmw and it comes with the the clips as well witch is good best just to get them both mate at that price
