clicking sound help~? which is central locking
LLamaFarm
Post Sun Jul 17, 2011 1:28 pm
theres a clicking sound coming from drivers side footwell, kinda near the speaker, iv done a search and the central locking ecu is there i believe? it happens when driving and clicks away when i turn engine off for a bit, it has not sequence its just random clicks???? can i just unplug it?
it goes away after 2 mins of engine off approximatly
cheers
**BANNED**
Post Sun Jul 17, 2011 2:24 pm
Central locking ECU is hidden under the speaker,just wondering if it is sat in a pool of water,causing this clicking!
Not good if it is,but the sunroof drains into this area and it is not unknown for the sunroof drain to become blocked....
Youth is wasted on the young.
LLamaFarm
Post Sun Jul 17, 2011 2:29 pm
plausable because there was a hole in the sunroof :0 ive just repaired it tho so wont fill up again if it is that, i took the speaker out earlier to investigate but i couldn't see and ecu as such, the speaker sits in a hole with just cables running through, didnt see water either tho, any more advice on where im going wrong or not looking is greatly appreciated
thanks
cecotto479
Caution Unreliable Seller
Post Sun Jul 17, 2011 2:35 pm
Remove the speaker and leave the cover off. Go for a wee drive and see if it's still clicking and if you hear it any louder or clearer. It might help you locate it.
1981 E23 735i
**BANNED**
Post Sun Jul 17, 2011 2:39 pm
With the speaker out,put your mit in the hole and pull the plastic tray out,the c/l ECU is held by two 10mm bolts just under the speaker hole.
It's not unknown for this area to fill with water,the cill should have drain points,have a look from under the car and clean them with a suitable small pointy tool.
C/L ECU can be taken apart if nessesary to dry it out,one with a buggered circuit board will be reasonably obvous when seen!
Have a look at the harness going through this area to the socket in the A pillar,there's two red/black wires there,these just loop through the door for no good reason,unless your car is one of the 0.001% fitted with heated door locks,so cut these away from the socket and join them together to eliminate their trip into and out of the door,this simple mod will cure most c/l problems.
There's more detail to be found in the Zone Wiki,link button at the head of this page.
LLamaFarm
Post Sun Jul 17, 2011 2:45 pm
ah cheers yes on investigation it is indeed this unit clicking away, the central locking dont work atm, i thought it may be a problem with the locking solenoid, but even if it was faulty what would cause this to click away when driving , are the doors supposed to lock when driving because i think this is my problem, its bone dry there just full of spiders and cobwebs :)
how does the heated door locks make it click away im confused, i would have thought it was the relay for the solenoid?
^^ thats a dumb question i know but im just new to e30 :/
**BANNED**
Post Sun Jul 17, 2011 2:59 pm
Have a read here;
http://www.e30zone.net/e30zonewiki/inde ... g_problems
I'm thinking 'red/black wire mod' will solve your problems....
LLamaFarm
Post Sun Jul 17, 2011 3:21 pm
yea i read that, just checked and the red/black wires already shorted together hmmm =/ im a little lost now, solenoid or ecu for central locking? the passenger door dont lock from drivers either, when i turn the key it clicks the relay but nothing happens
thanks
**BANNED**
Post Mon Jul 18, 2011 2:01 am
LLamaFarm wrote:yea i read that, just checked and the red/black wires already shorted together hmmm =/ im a little lost now, solenoid or ecu for central locking? the passenger door dont lock from drivers either, when i turn the key it clicks the relay but nothing happens
thanks
That sounds like a problem within the passenger door or it's A pillar connector...
LLamaFarm
Post Mon Jul 18, 2011 6:30 pm
cheers for pointers ill investigate further and post outcome
LLamaFarm
Post Mon Jul 18, 2011 7:02 pm
just if you know off top of your head, what wire is live with ignition on in a pillars, drivers and passenger side, and which colour actuates the solenoind for central locking on ether side?
just so i can force it to work to eliminate them
Post Mon Jul 18, 2011 7:47 pm
Infamous red/black is the permanent live at the A pillar (pre modification). Lock motor wires are plain blue a plain white, plus plain black (and the blue) for the deadlock motor.
Easiest place to work the locks manually is to use wire links across the locking ECU socket.
LLamaFarm
Post Mon Jul 18, 2011 7:53 pm
cheers ill give that a try, saves me dismanteling door cards that never go back on right to find fault
LLamaFarm
Post Mon Jul 18, 2011 8:16 pm
right, i just opened the drivers door and passengers was locked at the time, i linked 12v to blue and it started trying to lock door, but door was open so it didnt really work, it did this a few times, then stopped doing it, i checked voltage on the cables after this, blue was +12v and white also +12 volt, the unit was clicking away everyso oftern and it would drop to 0v momentary but i couldnt get doors to lock again after. i guess its the c/l unit now again as the solenoid did try and work so somthings not switching right in there im guessing.
thanks
LLamaFarm
Post Tue Jul 19, 2011 7:20 pm
cant get in boot now this is ******* stupid arrrrghhh i have to laugh otherwise id beat it basil faulty style
