Fuel pump wiring issues
Bristol_Jer
Post Sun Jul 17, 2011 11:42 am
I'm trying to get my m30 conversion started. There is no power going to the fuel pump when switching on the ignition or cranking.
If I bridge pins 30 and 87 on the relay base then I get power to the fuel pump. I get power at pin 86 when I turn the ignition on.
I have tried 3 different relays, all taken from cars that ran fine, and still no power to the fuel pump. Surely all 3 relays can't be dead?!
Crank position sensor resistance reads 492 ohms on my multimeter.
Is there something I'm missing here? Need to get it running asap :(
**BANNED**
Post Sun Jul 17, 2011 12:01 pm
Fuel pump circuit sounds fine,CPS sounds fine,do you have battery voltage at the green wire on your coil?
Youth is wasted on the young.
Bristol_Jer
Post Sun Jul 17, 2011 1:41 pm
Just checked, yes power to +ve on the coil (green wire) when ignition switched on
**BANNED**
Post Sun Jul 17, 2011 2:12 pm
Hummm,I was hoping for a break in the green,indicating an alarm issue!
So,ECU is refusing to switch fuel/spark on?
Bet that you have checked engine loom/body loom connector,and ECU plug...
looks to me like an ECU issue,have you a spare to try?
Bristol_Jer
Post Sun Jul 17, 2011 2:25 pm
Thank you for the replies :)
I don't have a spare ECU unfortunately, I'll see if I can get hold of one
I have changed the c101 plug as I have a later loom, but everything works and the power gets through to the fuel pump when I bridge the relay terminals so that must mean it must be wired up correctly.
I'll have a search on here in a sec and see if I can find out where I should be testing for power on the ECU plug.
Bristol_Jer
Post Mon Jul 18, 2011 7:18 pm
Right, it seems I have a spark now just to confuse things.
I have power to both 87 pins of the DME relay when ignition on. When fuel pump relay is bridged I get power to the fuel pump. To me this must mean that all 3 of my fuel pump relays are knackered? Or could this still be an ECU issue?
Post Mon Jul 18, 2011 7:54 pm
Totally knackered relays are very rare.
If you have sparks, then the crank sensor is working, and the ECU should also integrate the pulses to switch on the pump relay.
Only really leaves a wiring fault or the ECU, although ECUs are generally very reliable.
Bristol_Jer
Post Mon Jul 18, 2011 9:37 pm
Thank you Brian. I'll try another ECU and see how I get on. Hopefully that will sort it!
