Evening all,
Not had much luck with my sport the past few weeks, and its getting worse..
Heres the symptoms and problem as such, see if my theory is correct..
On starting the car from cold, she idles very lumpy and rough.. the car hunts as such (purrs, revs up and down) and sometimes even nearly dies so abit of throttle is needed (the reves purr up & down and the mpg gauge moves up and down too) tonight i had the car running for five minutes and approached a roundabout, braked.. and the car died because of this.
Once warmed up and after ten minutes or so of driving it is not too bad.. When you come to a stop it still hunts a little but then the revs settle and she idles correctly.
I have cleaned the airflow sensor and intend on checking the plugs tomorrow.
My theory is that the car is running too rich, or too weak and needs a good tune? could my idea be right?
Many thanks.
325i sport running rough?
svenga
d6dph
Inlet manifold gaskets?
I seem to remember I was told to take off the oil filler cap when it's running, If the idle drops then the gaskets are ok. It was something along those lines.
Other suspect would be idle control valve.
mrLEE30
The first thing I would check is for splits in the rubber hose between the AFM and inlet manifold/throttle body. Spray carefully some carb cleaner on the inlet side while engine is running, and change in engine RPM means there is an air leak.
Your assessment of it either running rich or lean or requires a service sort of covers all your bases!
