Power steering pipes pinhole leak
Davies31
Post Sat Jul 16, 2011 8:04 pm
I might as well buy a season ticket to this section of the forum. Anyway here goes again.
Got a tiny hole in the power steering metal pipe on the bend between the rack and the lower steering column connection. (The metal steering box pipes). I get a fine jet of ATF fluid across the engine compartment hitting the oil cooler pipes and then dripping onto the under-tray which results in the total loss of the reservoir each journey.
The question is this. Can I cut out a 15mm section and jubilee a piece of hose in. (Short term till I get a replacement pipe) Or is the pressure too great for this sort of bodge?
Anyone?
TouringMatt
Post Sat Jul 16, 2011 9:14 pm
Pretty sure i've read the pressure is uber high on the incoming side
Davies31
Post Sat Jul 16, 2011 11:18 pm
I don't know where I got the impression that it was pretty high pressure but your reasoning does confirm what I was thinking.
Cos the other option I was considering as a TOTAL BODGE in the short term was a blob of that metal epoxy stick stuff you kneed together. But if the pressure is that great then that's going to be a non starter!
Davies31
TouringMatt
Post Sun Jul 17, 2011 12:05 am
Knew i'd read it before, scroll down a few posts http://www.e30zone.net/modules.php?name ... ssure+rack
