Check Lamp Problem
turkeysneck
Post Wed Jul 13, 2011 10:12 pm
The little check lamp display in the roof is saying I have a washer fluid fault, It all seems fine. Do these things give a lot of trouble becaus I'm sicking of pressing the button to clear the light.
mrLEE30
Post Thu Jul 14, 2011 6:31 am
this light is truned on by a simple float switch in yout washer fluid bottle, when the fluid is low it lights the light. i assume your bottle is full of water? if so then you can replace the sensor which is attached to the top of the washer bottle. otherwise a quick fix is to remove the plug to the sensor and short the two wires, this will, or should, turn off the light permanetly.
jas025
Post Thu Jul 14, 2011 6:49 am
I had the exact same problem so got another sensor. Within 2 days the light came back on again so I shorted out the sensor as MrLEE says.
At least it doesn't beep at you like every bloody car nowadays. Do you get that if you fit the OBC with the "bong" under the dash? I'm not sure that I'd need to have that to see that my car was sh*t on fuel!
Post Thu Jul 14, 2011 9:18 am
There is nothing to stop the washer bottle sensor from turning in its hole in the side of the bottle.
The usual problem is that the float has been turned onto its side, and simply needs rotating upright!
turkeysneck
Post Thu Jul 14, 2011 5:44 pm
Thanks, I'll check that out.
