e30 320i speedo not working
w3rren
Post Wed Jul 13, 2011 8:54 pm
1988 E30 320i.
Speedo and trip counter not working.
The rev counter and all other gauges seem to be okay.
If I changed the sensor on the rear diff would this cure the fault?
Not sure if it is a common fault with these but it would make sense.
Are the sensors still available?
Part numbers and approx cost anyone?
Looks a simple fix 2 bolts.
less is more
ultralinear
Post Wed Jul 13, 2011 9:04 pm
Is this the clock's gear disintegration issue? It might be within the clocks itself.
Let someone who knows what they're talking about confirm or deny this!
w3rren
Post Wed Jul 13, 2011 10:06 pm
No idea what you mean.
My speedo is not operating, is it a common fault and is it usually the switch on the diff?
less is more
johnl320
Post Wed Jul 13, 2011 10:09 pm
xavier
Post Thu Jul 14, 2011 5:47 am
On going pain in the ?$;:@ of my 323i also. I have tried replacing the lead to the rear end, but this did nothing. I may need to bight the bullet and go to a professional auto electrician.
mrLEE30
Post Thu Jul 14, 2011 6:27 am
the cogs issue onyl affects the odometer, the speedo will still work.
99% of the time the issue is not with the sensor but the wire going to the sensor where it leaves the car body above the fuel tank and travels to the rear diff, here is it exposed to the elements and along with vibration tends to fail by breaking (although this may not be evident from the outside). the normal fix is to trace the wire back as far as possible, then cut the wire (leaving enough to join a new piece on) and replacing the entire outside portion of cable with a new piece. IIRC the sidelights use the same configuration plug, so a scrap car, if found, can donate the wire and plug.
If this does not fix the problem then next easiest thing is to swap the speedo or the whole instument clsuter for a known good one..thus establishing if the fault is wiring or cluster related.
Post Thu Jul 14, 2011 9:08 am
90% of speedo faults are the last 300mm of cable to the diff, and most of the rest are down to cracked soldered joints on the speedo circuit board, near the pins that plug into the main cluster board. Failure of the sensor in the diff is possible, but very rare.
