Touring rear 1/4 glass removal...
The_Haywood
Post Wed Jul 13, 2011 2:37 pm
... sorry to post requesting help again but having difficulty with this... i've removed the shadowline, the bottom metal strip, the little panel on the right and also the interior boot plastics.... but o'm still unsure as to how to remove the glass.... i've searched on the wiki page and also the search on the forum but i must be stupid as can't find anything :( please someone help
m8782538
Post Wed Jul 13, 2011 2:47 pm
it should just pop out, only the window rubber holding it in place. push in 1 corner to pop it out, then work your way around.
Its the same as the windscreen (i have this to do on mine), remove the trim and carefully push one corner until pops out.
Putting it back in is the fun part, need string or para cord, put it in the gap in the window rubber, place it whole unit over the hole, (2 man job) push gently from the outside while someone pulls the string or para cord from the inside so it pulls the window rubbers over the lip and into place, then re-fit all the trim.
The_Haywood
Post Wed Jul 13, 2011 2:55 pm
thanks dude.... does the bit of trim i marked with the dots come off too??? if so erm... how haha
m8782538
Post Wed Jul 13, 2011 3:04 pm
the trim with the "dots" those are for the actual trim catches?
Should be the same as the saloon and coupe models, just pop out from how it is now.
Try it, don't press to hard and break the glass or let it pop out and go flying as when it lands.......... :( smash.
BEMER_LAND
Post Wed Jul 13, 2011 3:11 pm
That metal strip you have dotted is bonded on with adhiseve, you will destroy it trying to pop it off, a heat gun might soften the adhiseve but never tried it myself.
and the glass is not the rubber type like on the 2 doors its bonded in so iv no idea how to take them ones out, proffesional would do it no problem
The_Haywood
Post Wed Jul 13, 2011 3:13 pm
after removing all the trim they don't look bonded in :? they do look like they're on a rubber.
m8782538
if its bonded, then its a pro job, you can get them out, but they are a nightmare to put back in.
BEMER_LAND
Post Wed Jul 13, 2011 3:17 pm
Ãav all the same bits removed as you do and left the dotted bit as was told it was bonded on. the glass however looks bonded to me if you look at the bottom where the trim is removed you can see the bond, and no rubber, there is rubber on top though not sure what thats for or how its kept on
The_Haywood
Post Wed Jul 13, 2011 3:56 pm
Apologies bemer land you are right, i've started cutting away at the sealent now to get it off, i can't figure out though if sealent is around the whole window or just bottom and sides
m8782538
Post Wed Jul 13, 2011 4:04 pm
If bonded be very carefull with a stanley knife and you can get them out, but its a pro job to get them re-fitted.
The_Haywood
Post Wed Jul 13, 2011 4:10 pm
I've fitted bonded windscreens before so 1/4 window should be eeeeasy :)
TouringTy
Post Wed Jul 13, 2011 4:29 pm
I have a similar question... but the glass I need to get out is the smaller bit on the passenger door. Anyone have a step by step, in the meantime I'll keep searching... thanks
The_Haywood
Post Fri Jul 15, 2011 5:58 pm
Well finally got it out.... What a bloody ballache.... Time for the other side UGH!!!
**BANNED**
Post Sat Jul 16, 2011 2:09 am
How did you get the trim bit off the forward edge,please?
And is yours for sale(n/s)?
Youth is wasted on the young.
The_Haywood
Post Sat Jul 16, 2011 6:26 am
Sorry no nothing off it is for sale, it's only being stripped back this far for respraying...
As for trim... I worked a small flat head screwdriver across the bottom to work the trim up and out and the side trim piece i used a flat head again just to pop it out of place and then used an old brake cable from a pushbike to cut the sealent off
**BANNED**
Post Sat Jul 16, 2011 9:17 am
The_Haywood wrote:Sorry no nothing off it is for sale, it's only being stripped back this far for respraying...
Thanks...been looking for a trim bit for a while,now,off and on....
That's currently 'fixed' with a spoonfull of P40!
Jozi
Post Sat Jul 16, 2011 11:44 am
Malc, you can get the trim from the dealers, about 35-40 quid. I destroyed one of mine on the red shell :D The long edge on the window is bonded the whole lenght and then there was a few blobs of sealant/glue near the top and bottom to hold it on. I found mine had started rusting from the inside but not in the same place as yours.
Haywood, did you get the trim off in one piece without damaging it? I to have both rear windows taken out of my shell. We used some sort of tool that vibrates (no, not the one wimin use to pleasure them sleves!) with a toothed blade on it, was a bit of work but we got it out on both sides.
---EDIT---
Part no's
51 36 1 947 183 - Covering Left - £37.14
51 36 1 947 184 - Covering Right - £41.63
Those are the prices I got about 6-8 weeks ago :thumb:
**BANNED**
Post Sat Jul 16, 2011 11:52 am
Thanks,Jozi,with BMWCC discount winkeye that is just about within my budget!
Jozi
Post Sat Jul 16, 2011 11:56 am
I was reading the thread about BMWCC, if only I was in your part of the world and had know about it long ago I could have earned the fees back in saving on parts I've gotten from BMW to date.
One thing I don't get is why are the priced differently, apart from being handed their identical pieces of metal.
The_Haywood
Post Sat Jul 16, 2011 10:34 pm
Jozi wrote: Haywood, did you get the trim off in one piece without damaging it? I to have both rear windows taken out of my shell. We used some sort of tool that vibrates (no, not the one wimin use to pleasure them sleves!) with a toothed blade on it, was a bit of work but we got it out on both sides.
i got a slight kink in the bottom of the large flat piece on the side.... i was going to knock it out and use some fine top stop filler on it... might aswell just buy new ones though :) i didn't think they'd still do them... i think i'm going to have to sign up to the bmw club for discounts as i may just buy a whole brand new set and shadowlines too.
