New problem with timing belt install from hell-moaning noise
clydesdale
Post Wed Jul 13, 2011 2:21 am
This is the 3rd time I have done the timing belt on this car. The other 2 times were a breeze. This one has been hell. I now can get the car started, but there is a moaning noise from the engine. So, I removed each belt and the fan and the moaning is still there. It is rpm dependent and you can hear it at idle. I replaced the cam seal, belt and tensioner. Could something be rubbing under the cover? What can be the source? I thought it would be a belt for sure, then I thought it could be the water pump, but that is new and it still moans with the belt off anyway. So, what is the next likely culprit?
Post Wed Jul 13, 2011 6:30 am
Belts too tight? That can be the cause of a moan stroke deep whine. Be careful as if it is too tight it can strip a tooth and you no the rest.
Had an old XR2i in once which had just had a belt. She'd returned the car once to the garage that fitted the belt saying it didn't sound right. I listened to it and at the time didn't thnk too much of it and advised her to return it yet again. Before she had time, it had stripped it's teeth and introduced it's pistons to the valves.
I got the job to strip it and on removal of the timing cover, I could barely twist the longest run of the timing belt through 90 degrees. It was like a steel bar more than a rubber belt! They had forced the tensioner over to a ridiculous tension. I rebuilt it and upon starting it, the noise was gone as the belt was at a more sensible tension!
I tried to et the manager of the garage to come over to see the issue before the strip down went any further but he declined. She never had any compensation from them and had to foot the bill.
clydesdale
Post Wed Jul 13, 2011 11:09 am
Yeah, I am thinking it is too tight as well. What I am worried about is, how did I make it too tight? Doesn't the tensioner take care of that?
Post Wed Jul 13, 2011 8:11 pm
clydesdale wrote:Yeah, I am thinking it is too tight as well. What I am worried about is, how did I make it too tight? Doesn't the tensioner take care of that?
Only if you forced it across really hard. If you just let the tensioner spring take up the slack, rotate the engine a couple of revs then loosen and let it tension again, it should be fine. Obviously checking the timing marks throughout the process is also a good idea.
clydesdale
Post Wed Jul 13, 2011 9:16 pm
Well, it turns out that this noise is a known problem using Goodyear brand timing belts on our cars. The bmw parts place that I bought it from says they have been getting complaints. I have sourced a continental belt and I will redo the belt change.
